April 09, 2006, 08:10
Phillip SanchezSeiko needs fixin
Is there a member out there that has time to work on a Seiko kinetic that has stopped running? I hope this is the right forum to ask this question. Phil
April 10, 2006, 08:57
Tim HillsHello Phil,
What is the movement/case number? Do you have any idea why it stopped?
Tim.
April 10, 2006, 10:23
Phillip SanchezTim, It is not a quartz.It is a kinetic. The case # is 702786 and reads mov't JAPAN and I dropped it. Thanks, Phil.
April 10, 2006, 10:26
Phillip SanchezI corrected that it was a quartz Phil.
April 10, 2006, 11:12
Tim HillsHi Phil,
The back of the case has a series of numbers that look like this XXXX-XXXX (ex. 5M43-0449). They can be alpha-numeric and are often scribed in a arch around the perimeter of the case back (sometimes faintly). I'll need to know those numbers. The ones you gave me appear to be the serial number.
Is "Kinetic" printed on the dial?
Tim.
April 10, 2006, 14:13
Phillip SanchezTim, the numbers are "5M43-0B69". Kinetic is on the dial and also "Titanium sports 100". Thanks, Phil.
April 12, 2006, 17:15
Phillip SanchezTim Hills has graciously agreed to repair this watch. Thanks to all who looked and to SS, who also offered to give it a look. Phil.
