A final report "Click" to Login or Register
I service the occasional watch for a few long-standing customers. Here for your delight is my latest report on a movement which might have been dropped ---
"In my opinion it is too badly damaged to re-use any parts - it is, as we say, a "write-off"
The balance hairspring is both distorted and mangled - I can't see this from just a fall unless there is also damage to the case signifying a long hard fall. One balance pivot is bent away from the vertical at an alarming angle. I don't see how this balance ever ran if there was no fall.
This movement has had some acquaintance with moisture. The case screws are rust welded to the movement - and although could be drilled out it could cause some damage to the pillar plate and train bridges. Any way there is further corrosion and physical damage to these parts and to all of the train wheels. In short it is (s)crap !
I truly recommend a complete replacement."
Dan
IHC Member 163
Picture of Mark Cross
So, quit beating around the bush, Dan....did you ever fix this one or not? Big Grin Razz
Regards! Mark
Posts: 3840 | Location: Estill Springs, Tennessee, USA | Registered: December 02, 2002
Geeesh!
Sounds like it fell in the pool and the following spring the pool cleaning guy stepped on it. Eek
Alas it was simply too far gone to revive, and all that was saved were a few minor parts. I had never seen case screws so rusted in as these two - I had to grind off the heads to take the movement apart.
Fortunately it is a common mvt. so replacement was easy.
DM
