Home made opener for oversized WW case backGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1736 |
Home made opener for oversized WW case back What does a guy do when he does not have an opener big enough to fit a modern watch with 1-17/32 across the pins on the case back? Make his own of course. This worked better than I could have wished for. The coolest part is that the board sits flush on the bench so I could focus on pressing down while I rotated, keeping the watch seated in the pins, minimizing the risk of scratching the back. Far easier than trying to manage a case opening wrench in one hand and the case in the other. I simply borrowed the replacement bits from another "adjustable" opener, measured the spread in two directions for a 4 point purchase on the case back... drilled the holes and plugged them in. ![]() | ||
Now that's using your noodle! I have a couple invictas that are in the same boat.. Bruce Byrd | ||||
Paul I use one of those http://www.microbattery.com/Ad...ch-Case-Back-remover [Adjustable Waterproof Watch Case Back remover] ![]() | ||||
| IHC Member 1736 |
Peter, I gave up on two pin case openers two years ago when I ruined a case with one. They are just too awkward for me to manage and far too risky. I do use my two way adjustable three pin spanner and have a nice selection of purpose built multi-pin case wrenches that fit most watches... but none were large enough to fit this case. | |||
