January 29, 2009, 21:56
Keith KlimkowiczIllinois "The Master" 16-size and 12-size Watches
Hi
Could some one tell me what model these are from the serial numbers.
1. #4495542 16s 17j Adj. Marked "The Master" on the movement, the dial is marked "Illinois Master". It is in a Derby case.
2. #4897821 12s? 19j Adj. 3 Positions marked "Imperial" on the movement and on the dial.
Thanks for any help.
January 29, 2009, 22:17
Tom BrownKeith
So far #1
4494001-4496000 16s pendant set open face 17 jewel model 7 grade 305 Illinois.
January 29, 2009, 22:23
Steve MiddlesworthKeith,
#2 is a 12 size 19 jewell Model 3 of which there were 5330 made in 7 runs. Yours was made in 1927 and is a grade 407. It was made in the second to last run which included 1000 serial numbers.
Steve
January 29, 2009, 22:25
Tom Brown#2
4897001-4898000 12s pendant set 19 jewel open face model 3 grade 407. I wonder if Imperial was a private label.
January 30, 2009, 15:01
Tom BrownNice looking watches Keith, I like the Imperial one the most, like that lettering color.
February 07, 2009, 15:57
Keith KlimkowiczHi
Looking for a replacement dial for this watch.
February 07, 2009, 21:19
Keith KlimkowiczThanks Lin
Good to hear from you! I miss your posts. Glad you are feeling a little better. The power of the masses wishing you good health and recovery has pulled you through.
Keith
February 13, 2009, 22:20
Keith KlimkowiczHi
Just picked up this 12s Illinois marked "The Master" 19j serial #4512500. This one will fit nicely with the 16s posted above.
Would you guys be so kind to look this number up. Please!
Thank you in advance.
February 13, 2009, 23:18
This one is a grade 406 manufactured in 1924. There were 92,140 made in 101 runs between 1913 and 1926.
Steve
February 21, 2009, 14:38
Keith KlimkowiczHi
Found another Illinois 16s "The Master". This has the same style dial but only in a metal dial. Take a look.
