Illinois Watch Company Research Forum
1 of 100Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
here is that 100 watch run bunn | |||
17 jewel adjusted to temp 5positions isochronism | ||||
17 ruby jewels s.n. 2117954 | ||||
sorry about the pics.ill try to get better ones this weekend. | ||||
i wounder what this is worth today? | ||||
thanks Lindell i wounder why that other book said there was only 100 in that run?also can you tell me do those hands look to be the ones that should be on that watch? james | ||||
| IHC President Life Member |
Jim, We are speaking of a different place in the same book, there were only 100 in the particular run in which your movement was produced, but of the variant, which is the way your movement was marked there were apparently about 3,000 of that variant produced. Both the "100" and the "3,000" are true numbers but all the information must be used together and understood for what it really means, not taken out of context. Think of it this way, you have a certain year and body-style of car. On the day your car was assembled in the factory there were only 100 of that style built but over the entire model year there were 3,000 made. The fact that only 100 of that body style were assembled at that one particular time is of little or no consequence, that number must taken in the context of the total number of them produced over the entire model year. When Dave Abbe showed you an excerpt from the Illinois Encyclopedia, the portion he used clearly showed a "3,200" total for Open-Face on that particular 17-Jewel Bunn variant on the last line. Dave also mentioned that your movement was from a "100 piece run" which is true as it helps place it chronologically but that one point has no real effect on rarity, desirability or value and therefore really is not a factor in and of itself. It is important to understand that each slight difference in movement markings is an individual "variant" and those differences are what can greatly effect value. For example, there are seven variants of the Grade 163 Bunn Special and they vary in value from $3,000.00 to $30,000.00 based upon the rarity of the variant in question. Understanding this fully can become complicated at times but it is a fascinating subject. Looking up an Illinois number to determine year of production and how many were in that run is only the first step, one must then continue the process and research the movement fully in order to have complete information. Please read carefully what I posted after you in the "Illinois Pocket Watch Question" for additional information about your particular movement. Bottom line, if your movement markings are identical in every respect to the image I shared in that topic and above in this topic then it is that same variant. Hope that helps explain variants a bit further, Lindell About the hands on your movement, those shown in your picture appear to be replacements. Hands common to 18-size Bunn and Bunn Specials... ![]() | |||
what would we do without you Lindell? | ||||
Glad we were able to help you Jim | |||
i know not a day go's buy i dont learn something,it may not always be what i want to here but the truth is the truth. | ||||
