Note the red dot dial to distinguish this commercial grade watch, typically referred to as a Trolley Watch, from the Rail Road grade watches of the era.
Somewhere in this time frame, the seconds register also became much larger in diameter than earlier models. It will take a few examples to narrow down the transition period and which models this larger seconds section dial belong to. This example has the smaller seconds register. See the 305 further down to see an example of the larger seconds register.
Illinois 4 foot dial - These dials were released in the transition era from model 5 Getty to model 6 movements. The extra foot could be cut to fit either the model 5 or the model 6 movement. This one is cut to fit a Getty model 5.
If you like the idea of this project, please add examples of your own.
This is all about getting it right. You are not going to hurt my feelings if I've made a mistake above that needs to be corrected... or if you have additional information I can add to certain post to improve the information.
Probably best to email me direct rather than clutter the entries below with corrections... but either method is perfectly fine.
If we put the production date, Illinois, model and grade, plus the words "correct dial"... it will pop on any search for a correct dial with matching parameters.
My hope is that with enough entries... we can gather enough examples to define where the cut offs are for a few things like: - red dot dial start and stop - various examples of "white enamel dials" and what models they are found on - dial options prior to the red dot dials - script/curved/straight line Illinois signatures - Arrows in/Arrows out/half circles/diamonds...
Some of these questions have already been answered in other post... I just need a bit of time to go find them... Things like... the straight line signature changed to a curved signature in either 1914 or 1917, depending on which post you read and believe.
I'm going to reserve the next entry space for consolidated notes that I'm able to glean from other post and comments further down in this post as it gains entries.
Paul, I commend your effort. Make sure that your "correct dial" designations don't imply that the dial shown is the only correct one. That generally isn't the case.
Ethan brings up an excellent point. During the pre-factory cased years... movements were purchased at or from a distributor. A jeweler, mercantile, your local inspector...
Case, dial and hand combinations could be chosen right there at the counter. Most conform to generally accepted conventions. I'm hoping that some of these will become more apparent as known examples continue to be added to this thread.
Things like, thin spade hands go with small Arabic numerals and bold spade hands go with bold Arabic numerals.
The long thin spades with a distinct waist are correct for early 18S Roman Numeral dials...
I'm hoping Buster and some others will offer up some examples of correct Gothic dial and hand combinations to help us isolate the years and models those are correct to.
The dial, hand and movement combinations demonstrated in the Blue Hampden book have been assimilated from known examples believed to be correct. These are not hard and fast rules... but more a process of data stacking.
You can email photos of watches or scans of catalogs to me for entry if you don't want to spend the time cropping them and building the narratives.
Movement serial number 1451890. 1 of 1,000 total in grade. Model 4 Sangamo Getty 21RJ-HN4L-T6PI-RRG Ruby jewels in gold settings, gold balance screws, polished gold train wheels and rounded spokes, patent regulator. Gold inlaid ribbon (second) pattern, damaskeened nickle black filled engraving. This watch is one of a few "pink" versions within this grade.
