The serial number 4307549 shows a 16 size 21 jewel model 9 lever set open face grade 806 made in 1923. It should be adjusted to 3 positions jewels in raised settings, rounded spoke gold plated train wheels with a patent regulator. Tom | |||
Thank you very much Tom Happy New Year to you, realiable has ever, I can't give you any interesting names to research. I'v had a bit of bad luck with my watch, it fell out of my pocket when playing football with my grandsons, I kicked it instead of the ball. Now it's back to square one, new balance staff, hairspring ect ect, so I'm not a happy camper just now. ![]() Ho has the Criterion movement any value would you know I have a chance of buying it from a friend over here, it needs repairing I'm just wondering if it's worth my time putting it right ![]() ![]() Thank you again Tom regards Ian. | ||||
Ian Sorry to hear about your misfortune with you pocket watch. I really can't tell you the value of the grade 806. If you need any parts to repair your other one let me know & I can search through my parts movements. Tom | |||
Tom. Thats a kind offer,I really appreciate your concern, yes I will be in need of some parts, I dismantled the movement to check whats damaged, I thought the wheel pivots were bent, but after a good examination I found only the fourth wheel pivots badly bent ![]() The brand new balance staff pivot is broken, and the hairspring is mangled, I'v checked over all the jewles, it seems the main body jewles are ok apart form the fourth top jewel it's cracked, the balance jewels must have taken a good knock they are damaged,the balance wheel needs some work . The crystal poped out it's OK ![]() I think I got off lightly with minimal damage I think ![]() ![]() Thanks very much Tom. Regards Ian. | ||||
