Need some info on this Illinois...please "Click" to Login or Register
posted April 28, 2008 22:54
I recently purchased an Illinois, 17J, serial 4028673. The case is stamped Illinois Watch Case Co Elgin Tivoli Gold F 14K guarantee. I can't discover as much info on the Illinois like I could on the Elgin's and Waltham. I think it may be a 1906. That's all I know. It's on the way here. I got it at a good deal, so I could not resist, almost spontaneous. I will post a few pics also.
posted April 28, 2008 22:56
And I would appreciate any info. I don't even know what size it is....Thank's
Stevan
posted April 28, 2008 22:57
movement:
posted April 28, 2008 22:59
case:
posted April 28, 2008 23:02
It's got some wear but it looks clean and a hair line around the 20/30 second reading. I may have to replace the window and have it cleaned up. Don't know yet, but that's ok, If need be, I will send out in Texas.
Stevan
Picture of Brian C.
posted April 29, 2008 07:33
quote:
4028673
Stevan,
Your watch should be a 12s, 17j, Mod.3, Of, sw/ss, adjusted, double roller, circa 1922. Hope this helps.
Brian C.
posted April 29, 2008 09:59
Thank YOu Brian,
I'm new here and an amateur to pocket watches. I'm still learning so what does sw/ss mean? And I'm guessing Of is Office? The 1922 threw me because I looked up the serial number in the Illinois data base and saw where it indicated 1906 for that serial number. Thanks for the information.
Stevan
IHC Member 1101
Site Moderator
Picture of Steve Middlesworth
posted April 29, 2008 17:42
Stevan,
sw/ss means it is stem wound and stem set as opposed to one that would have a lever under the dial and then would be called lever set. the Of here is referred to Open Face as opposed to a hunter cases that has a lid over the face.
Steve
posted April 29, 2008 18:37
Thanks Steve,
I need to study up on this sort of stuff!
Stevan
