Illinois Watch Company Research Forum
14K Solid Gold SangamoGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
inside back 1236505 number (Unfortunately, a small "Gold Test" groove was cut into the case edge -Right side of image) ![]() | ||||
cuvette ![]() | ||||
inside cuvette, and another "Gold Test" scrape on the cuvette - Right side of image. ![]() | ||||
4720085 movement ![]() | ||||
back of case ![]() | ||||
Sean, I’m glad you were able to save this watch from the scrapper. The watch guide is showing your watch as a **** four star. The condition looks up there too. I’m curious as to approximately how much the case weighs? It’s interesting the watch you have is the first unmarked 60-Hour solid 14K gold example to show up for the database between the years of 1926 to 1930. Congratulations on a great find. RR | ||||
Because of the rarity and the STORY. The file mark will not hurt the case at all. Excellent find. 1 of always trump condition. | |||
Thanks for the replies! The case alone weighs about 51.7 grams (I did leave the crown/stem installed). the Gold Buyer math goes like this: 51.7 Grams of 14K (14k =.5833 pure gold content, but the jewelers always use .585)means, .585 X 51.7 = 30.24 grams of pure gold. Then we convert Troy Oz.to grams, 1 troy Oz.=31.1034 grams So...30.24 / 31.1034 = .9723 Troy Oz. of Gold in the Case. If gold spot is $1750.00 per Troy Oz. then, .9723 X 1750 = $1701.67 worth of Gold Scrap in the 14k Sangamo Special Case. I offered a few hundred dollar markup premium for the complete watch and got it! Keep in mind the scrap dealer will never get 100% of the gold in scrap, as it is always discounted some percent (3 to 5% is common). I try to avoid pricing the movements alone as I only pay a premium for "Complete Watches". Just movements alone are heavily discounted as they are only part of a pocketwatch. I pay $5-$30 dollars for movements from the scrap guys... See attached images Thanks, Sean ![]() | ||||
Here is the complete watch on the scale. ![]() | ||||
Here is just the movement ![]() | ||||
And for reference a White Gold Filled Sangamo Special ![]() | ||||
Sean, Send all those movements out west. Patrick and I will split them up. Maybe let us build our war chests to step up to complete watches some day | |||
To acid test such a beautiful case that is clearly hallmarked has to be a monumental act of vandalism! Someone ought to take a file to whoever did this! Best Regards, Ed | |||
I totally agree!! They just like to cut deeply enough to make sure it really is "Solid Gold". They explained if the case is marked both 14k and .585 they would not file. However, they have been confused/burned by the so called "Warranteed 14K" marks that imply solid Gold, but are really Gold Filled cases. So any cases that are questionable with a mark or they are not familiar with get the file and acid test. Sean | ||||
