April 03, 2009, 14:46
Tom BrownHoward Series 11 Rail Road Chronometer Serial Numbers Database
This is the serial number, case number, etc. list I have been working on for
Howard Series 11 Rail Road Chronometers.
I started gathering this list when I noticed a watch David Abbe posted had the damaskeened pattern & I had not seen that before.  I started searching this site, Ebay & any where else on the web I could find information on these.
There are other differences in different runs of the Series 11, some have a bar click, some rotary, some have the arrow & star symbol, some do not.  It also appears that these only came from the factory in Keystone/Howard cases (Keystone owned Howard).  They used either a swing out case of the double cross bar safety bow case.
The only way I could post this & keep my format was to post it as an image, if there is a trick to posting & keeping your original spacing I would like to know how to do that.
You will notice that the 1st few serial numbers are not complete & every serial number does not have the complete info.  Some of the images & posts I looked at either I could not read them information of the images or it wasn't listed.
This is a work in progress, if you see a benefit in doing this please send me any information you have & I will add it to these lists.
One thing I did not know until Lindell told me is there were yellow gold & green gold cases & white gold cases, so you will see one in the list labeled DCBG & that means Double Cross Bar Green. He also told me that there were pattern back cases, since when I started this I wasn't paying attention to the cases I did not note their color or if they had a pattern back, so I need to go back & try to determine that.
Look forward to hearing any comments.
Also if anyone has a break down of the run numbers for Series 11 Chronometers I sure could use it.
__________________________________________________________________
_______
E. HOWARD SERIES 11 RAILROAD CHRONOMETER DATABASE_______
________________ACTUAL MOVEMENT AND CASE COMBINATIONS______________
_____Mvt Number___DMK____Click___A&S__Case Number___Case Style________
______1114175_____No_____Unk___Unk____5425510_______SO/Y _________
______1181139_____No_____Bar____No ____1012231_______SO/? _________
______1181162_____No_____Bar____No ____Unknown______SO/Y _________
______1181758_____No_____Unk___Unk____1587836_______DCB/?________
______1182455_____No_____Bar____No____1511159_______SO/Y _________
______1182705_____No_____Bar____Unk___1512389_______SO/Y__________
______1182993_____No_____Bar____No____1017303_______SO/? __________
______1183344_____No_____Bar____No____1010857_______SO/Y___________
______1183582_____No_____Bar____No____Unknown______Unk  __________
______1183706_____No_____Bar____No____Non-original__________________
______1183759_____No_____Bar____No____1013649_______SO//? _________
______1183955_____No_____Bar____No____Non-original__________________
______1183966_____No_____Bar____No____15013195_____SO/Y___________
______1184861_____No_____Bar____No____1502702______SO/Y___________
______1185000_____No_____Bar____No____Unknown______SO/? __________
______1185024_____No_____Bar____No____Non-original__________________
______1185031_____No_____Bar____No____1503163_______SO/? __________
______1185391_____No_____Bar____No____1502938_______SO/Y___________
______1185478_____No_____Bar____No____???????_______SO/Y___________
______1185530_____No_____Bar____No____1008477_______SO/? __________
______1185555_____No_____Bar____No____1016023_______SO/Y __________
______1185564_____No_____Bar____No____1502906_______SO/Y___________
______1185965_____No_____Bar____No____1502603_______SO/Y __________
______1186000_____No_____Bar____No____Unknown______DCB/?__________
______1186119_____No_____Bar____No____Unknown______Unk  ___________
______1186149_____??______???____No___Unknown______Unk  ___________
______1186390_____??______???____No___1587840_______DCB/?__________
______1186747_____??______???____No___Unknown______Unk  ___________
______1186982_____No_____Bar____No____Unknown ______Unk  ___________
______1188407_____No_____Rot____??____Unknown______Unk ____________
______1188457_____No_____Rot____Yes___1531469_______SO/Y___________
______1188589_____No_____Rot____Yes___1533480_______SO/? ___________
______1188671_____No_____Rot____Yes___Unknown______DCB/W_________
______1189184_____No_____Rot____Yes___1546053_______SO/Y __________
______1189191_____No_____Rot____Yes___1588423_______DCB/?__________
______1189385_____No_____Rot____No____Unknown_______SO/Y___________
______1189393_____No_____Bar____Yes___1559070_______DCB/W__________
______1260328_____No_____Rot____No____Non Original Case_____________
______1260640_____No_____Rot____No____Unknown______Unk  ___________
______1260688_____No_____Rot____No____1513093_______SO/? ___________
______1260895_____No_____Rot____No____1080888_______SO/Y____________
______1261156_____No_____Rot____No____1515712______UNK__BOX LABEL___
______1261232_____No_____Rot____No____1526088______SO/Y___________
______1261559_____No_____Rot____No____Unknown______SO/Y___________
______1261783_____No_____Rot____No____Unknown______Not Howard Case__
______1261981_____No_____Rot____No____1087472_______SO/? ___________
______1262155_____No_____Rot____No____5451896_______SO/Y ___________
______1262871_____No_____Rot____No____1029336_______SO/Y____________
______1263421_____No_____Rot____No____Unknown_______SO/? ____________
______1263558_____No_____Rot____No____Unknown______Not Howard Case___
______1264038_____No_____Rot____No____1013590______SO/Y_____________
______1264355_____No_____Rot____No____Unknown______SO/? ____________
______1264367_____No_____Rot____No____1035569______SO/Y_____________
______1283464_____No_____Rot____No____Unknown______SO/Y_____________
______1283595_____No_____Rot____No____1038805______SO/Y_____________
______1283615_____No_____Rot____No____Unknown______Unk  ____________
______1283674_____No_____Rot____No____1037221______SO/Y_____________
______1283814_____No_____Rot____No____1526830 _____SO/Y ____________
______1311241_____No_____Rot____No____1040735 _____SO/Y ____________
______1311369_____No_____Rot____No____1043809 _____SO/Y ____________
______1312793_____No_____Rot____No____1051275______SO/Y ____________
______1312874_____No_____Rot____No____Unknown______????_____________
______1312955_____No_____Rot____No____Unknown______SO/? ____________
______1313299_____No_____Rot____Yes___Unknown______Hinged back_______
______1313738_____No_____Rot____Yes___1524464______SO/Y_____________
______1313837_____No_____Rot____Yes___1524809______SO/Y_____________
______1317001_____??______??_____??___Unknown_____SO/? _____________
______1317165_____No_____Rot____Yes___1524855______SO/Y _____________
______1317351_____No_____Rot____Yes___1524999______SO/Y _____________
______1317795_____No_____Rot____Yes___1525888______SO/? ______________
______1318051_____No_____Rot____Yes___Unknown_____SO/Y ________
______1318767_____No_____Bar____Yes___1531417______SO/Y Santa Fe Engraved on back
______1360097_____No_____Rot____Yes___Non-original___????_________
______1360337_____No_____Rot____Yes___1558672_____DCB/W__________
______1360399_____No_____Rot____Yes___Unknown_____????__________
______1360697_____No_____Rot____Yes___1555082_____DCB/W _______
______1361105_____No_____Rot____Yes_____Unknown_____DCB/Y________
______1362372_____No_____Rot____Yes_____1569313_____DCB/?________
______1362520_____No_____Rot____Yes_____Unknown_____DCB/Y________
______1362577_____No_____Rot____Yes_____1566632_____DCB/G_Boxed Set
______1362677_____No_____Rot____Yes_____1566581_____DCB/?_________
______1362755_____No_____Rot____Yes_____311565______DCB/Y________
______1362787_____No_____Bar____Yes____1569284______DCB/G_________
______1374365_____No_____Rot____Yes____1588526______DCB/Y_________
______1374718_____No_____Rot____Yes____9679504______???????_________
______1378550_____No_____Rot____Yes____1580741______DCB/W__________
______1378778_____No_____Rot____Yes____1580702______DCB/?__________
______1378790_____No_____Rot____Yes____1583321______DCB/Y__________
______1378856_____No_____Rot____Yes____9679438______DCB/Y__________
______1385055_____Yes____Rot____Yes____9706635______DCB/Y__________
______1385127_____Yes____Rot_____Yes____1555113_____DCB/Y__________
______1385499_____Yes____Rot_____Yes ___9774084_____DCB/Y__________
______1385535_____Yes____Rot_____Yes____Unknown_____DCB/Y__________
______1385537_____Yes____Rot_____Yes____Unknown_____???????__________
______1385768_____Yes____Rot_____Yes____1591916_____DCB/W_________
______1396135_____No_____Bar_____Yes____1591811_____DCB/?__________
Abbreviations:
DMK= Damaskeening
DCB= Double Cross Bar Safety Bow Case
SO= Swing Out Style Case
Y= Yellow Gold Filled Case
W= White Gold Filled Case
G= Green Gold Filled Case
P= Pattern-Back Case
© 2016 Internet Horology Club 185 - All Rights Reserved Worldwide.
