Clock Repair Questions and Answers
Chimes At 3 Minutes After Hour and Half Hour?Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
My Banjo clock chimes at 3 minutes after the hour and 33 minutes after half hour. There is no washer on minute hand. How can it be fixed? Thanks. | |||
What movment is in the clock? I assume you are speaking of the stike rather than chime? If the mechanism has a cam around the center arbor, on the front of the movement... you can move it to strike correctly with a screwdriver by pushing against the lifting part of the cam. If the mechanism has "lifting wires" on the center arbor on the inside of the movement...you can bend them slightly. | ||||
Hello - If your movement is a Hermle (or many of its other direvitive names) the problem can be handled easily. Unscrew the hand nut. Remove the minute hand. Using a square rod - insert into the hand center. turn the hand in either direction to correct. The hand should move somewhat easily - if not more force is required. I would suggest a proper tool for this use. They can be purchased at Merritts in Pa. Good luck. Bill William N. McCormick | ||||
