sligh clock with hermle movement is out of sync "Click" to Login or Register
posted July 30, 2007 19:28
my sligh grandfather clock with a hermle movement is out of sync. when the chimes go off it is about 4 minutes after the hour. what can i do to correct this. thanks paul
Posts: 10 | Location: Fort Myers, Florida USA | Registered: April 09, 2007
posted July 30, 2007 20:31
Paul,
The minute hand on your clock should have a brass bushing in the center. Remove the nut on the hand shaft and pull the minute hand off of the clock. The bushing has a square hole to fit the hand shaft. The hand orientation can be adjusted by placing something square in the hole to secure the bushing, then rotating the hand. I have a screwdriver shaft that I have tapered (on a grinder) to fit most square holes. The final adjustment (maybe a degree or so) can be made by bending the hand slightly.
Best of Luck,
Dick
