Mauthe clock movement with seatboard "Click" to Login or Register
posted October 18, 2006 21:54
Hi all: I need a mauthe clock movement and dial. movement is seatboard mounted. has a 13" penulum and a 8" dial. the case is 24"x11"x5" inside dimenions. sure would like to make this clock a clock after some one remove the movement and install a quartz movement. that should have been a no-no. need help! thanks and have good day. moe
Posts: 8 | Location: Sealy, Texas in the USA | Registered: May 06, 2006
posted October 18, 2006 22:16
sorry I didnot mention that this is a germany box clock with a mignon gong. thanks moe.
posted October 20, 2006 22:48
Moe,
Many of the later Mauthe clocks had Hermle movements. I know you do not have much to go on, but you may be able to find a replacement Hermle movement and dial to get the clock back into shape.
Can you post a picture or two?
Dick
posted November 18, 2006 22:05
Hi: Dick I found a junghans movement with a seatboard that worked just right. reworked the 8" dial that they had for the quartz movement and mounted it on the movement. reused the brass bensal. reshallaced the case. it made one beautiful german box clock. i know this is a married clock put it is not a quartz! have a good day. moe
posted November 18, 2006 22:22
Dick I found a junghans movement with a seatboard that worked out just right. I reworked the 8" dial to fit the movement and reused the brass bezel. reshellaced the case. it made one beautiful german box clock. i know it is a married clock put it is not a quartz! have a good day. moe
posted November 18, 2006 22:30
sorry about the double message. i am not computer person. moe
posted November 19, 2006 21:29
Moe, just in case you would be interested in some history of Mauthe
http://www.gleuenberger.com/clocks/MautheClocks.htm
Posts: 152 | Location: Telford, Pennsylvania USA | Registered: May 21, 2005
