May 05, 2011, 07:46
Francis BowmanStar 2740 Swiss Staking Set
I just bought a staking set off ebay and have no jolly idea of that the stake are used for. there are 96 stakes and some other little thingys. if any one has the same set, that could email me with what they are used for I would be grateful..In Advance thanks...
May 08, 2011, 05:07
Francis BowmanThere was nothing showing what the punches are. or what they are used for. there is no numbers on the stakes at all but the brand name. ihave searched the net, i will put up a photo if that helps. and thanks to those whom have helped out .
May 08, 2011, 12:11
Richard RomeroFrancis,
I've got a manual for K&D staking sets. It's a large file so I'll have to send it via e-mail. You should be able to match up the stakes by looking for similar styles.
Hope it helps,
RR
May 09, 2011, 06:06
Francis BowmanGentleman thank you for the information. I was complelty lost and had NO idea at all.People told me that the Staking Set would be the best tool a man/woman could have when it come to doing pocketwatches and WW, as well... Lindell there is very little rust on any of the items, i pull it completely down and sprayed it with WD -40 and cleaned out the seat. made sure it fitted together well and there was movement and used the alignment tools to make sure it wasnt bent... NO there was nothing on the box stating it was a Star 2740, just what the seller said it was. How ever on the stumps and punches it say "star Swise" there is nothing about the model 2740 at all......the item u fist mentioned used to pick up the stumps one of the prongs is broken, that is the only set back to the set and not knowing wat they are used for,but now i can know more than i did before.. I see that the K&D set is a lot different in the stumps, the inverter set is much better design.
