Horological Tools, Books and Miscellaneous
Hand removing toolGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Which type are best for a novice? The 2 bar kind or the tool you squeeze. Wher do most of you buy your tools? Thanks again, Ed | |||
| IHC Life Member South-Bend |
Something like this works pretty good, Hand Removal Tool You can often find them on ebay for quite a bit cheaper than this. | |||
Frank, That looks like it would be easier to use than the 2 bar removers. | ||||
It's much easier to use than 2 bar removers, a lot safer to use, and usually much safer for the dial. | |||
| IHC Member |
I agree with Frank- most of the time. Sometimes I use the two bars when the hands are stubborn-and that happens alot with pockets in poor shape. Just make sure you have a little piece of paper or something cut out(like a pie missing a piece)to fit between the dial and the tips of the hand removers. Marty | |||
