Uncle Larry in Canada or Tom at Dashto Horology may have something for you Shawn. Just a thought at this time. Ebay sometimes has these type of things too.
Bob My L&R Master Cleaning machine has a 50ohm wire wound resistor as a heating element...draws about 2AMPS when turned on, and produces quite a bit of heat. You might find a similar size at an electronics supply house.
Posts: 886 | Location: Nebraska, in the U.S.A. Heartland | Registered: November 22, 2002
Wayne, I have a question. In the picture that you provided,is the 50hm resister you refer to ,the one on the left ,being held in place by a strap.Or is it the rehostat shown in the picture.
I have never seen the inside of a cleaning machine.
Frank
Posts: 440 | Location: Philadelphia, Pennsylvania USA | Registered: January 28, 2003
I guess I should have said rehostat,after seeing Wayne's picture. I am not familiar with electrical parts. I thought the parts were made just for this machine and may be out dated. I will try an electronics supply. Thanks for the help.
Posts: 5 | Location: Greenville, South Carolina USA | Registered: October 30, 2003
Getting back to this post,I was looking thru one of my catalogs and found a listing for rheoststs. 50 Ohm @100 watts, 50 Ohms @150 Watts. They are the ones Bob would probably be interested in,assuming he has the same model as you Wayne. The catalog is from '02, so the prices may have changed. 100 Watt-$36.87, 150 Watt- $46.92.
Company name:Newark Electronics (1-800-463-9275) Website: www.newark.com
Frank
Thanks for the help Frank and Wayne. I thought I had the problem solved. I went to a couple of local electronic supplies and found a replacement for the rehostat. The one I took out had only two conections(one had been cut off) the new one has three. Is the rehostat in your machine only coneted in two places or is mine a homemade repair.
