July 20, 2003, 15:59
Wayne C. AndersonFahys Watch Case
Found a 16size Hunter watch case, Fahys SN7249262 "WARRENTED TO WEAR PERMANENTLY" that has a Waltham "Travler" 7 jewel movement. I wonder what they meant by Warrented to wear Permanently? Thanks
July 20, 2003, 16:20
Aaron BereiterWayne,
I have an Elgin case marked "Double Stock" which i believe it about equivilant to the "Permanent" marked cases. I was told it ment just that. Guaranteed to wear permanently. Meaning, if you wear it to brass they will replace it.
I bet you would be hard pressed to get one replaced now though.
Wouldnt that be nice?
Aaron
July 20, 2003, 17:37
Lindell V. RiddleAaron's right on the money Wayne! All the Fahys cases were well made but the "Permanent" and later "Double-Stock" were heavy with gold and considered the best Gold-Filled cases made.
The practice of case warranties eventually came under governmental scrutiny and from 1923 on the cases will have names on them (like "Double-Stock") but no reference to specific wear periods were permitted. After that legislation took effect specific time guarantees on wear for watch cases were a thing of the past. Instead they once and for all had to state the gold content on any gold jewelry item and that included watch cases.
Bottom line, you have a very high quality case there.
July 20, 2003, 21:41
Mike MillerI have one of those Fahy's marked "permanent" It has lived up to its name. It did wear through to the brass... And the wear is now a permanent feature to the case
Sorry, couldn't resist
Mike Miller
