Hi Brian I've seen a item very similar to what you have pictured in a drafting set. The only thing was that the item in the drafting set came to a sharp point. I can't remember what it was called,maybe someone else can.I have one laying around the house somewhere. It may have been used to hold a thin lead, not sure.
Frank
Posts: 440 | Location: Philadelphia, Pennsylvania USA | Registered: January 28, 2003
Brian C. A pallet warmer and a pallet fork holder are the same? I'm not a watch person, so I'm not sure what you mean by Julian giving the same answer. Mike C.
Posts: 152 | Location: Telford, Pennsylvania USA | Registered: May 21, 2005
Hi Michael, Yes a pallet warmer and a pallet holder would be the same thing. A pallet warmer would be the correct term to use, it holds the pallet when replacing or adjusting the pallet jewels. Brian C.
