Hi Everyone,just bought a neat little lathe from a local Amish man(Ray Hostetler),he is making these along with a mini mill and a few other tools for the hobby oriented.His original intentions for making this was for model makers to make parts for their small projects.I thought I would give it a try for polishing pivots etc..I have used it a few times and seems to work well for what I need it for,I do have a larger 7x12 Central Machinery lathe but like this one for the small 2" chuck(I think it would grip a human hair) and open work space.To give you an idea of the size the board it is mounted on is 24"x 8" and weighs about 24 pounds. It has a 1/5 horse motor that is variable speed from 0 to roughly 2200 rpm and came just as pictured for under $350.Check out the pics and if there is some interest I will gladly put you in touch with Ray,he will only be available by phone but if you have any questions or specific measurements I will try to answer them for you.Ive added one picture and links for a couple more,thanks. Kent
http://www.ken.advertisnet.com/lathe2.jpghttp://www.ken.advertisnet.com/lathe3.jpg
