Is this South Bend 211 a fake? "Click" to Login or Register
Picture of Ernie Loga
posted May 08, 2008 01:06
I tried to look the serial number of this south Bend grade 211 watch up in the serial number database and I got an error message that the number is not in the South Bend Range of numbers.
Grade 211
Posts: 900 | Location: Wisconsin in the U.S.A. | Registered: April 28, 2008
Wristwatch Host
Picture of Tony Dukes
posted May 08, 2008 20:59
Ernie,
I believe this South Bend movement is the real deal.
Tony
Posts: 1953 | Location: Atlanta, Georgia in the U.S.A. | Registered: August 01, 2003
posted May 08, 2008 22:57
Tony:
thank you for your reply. But, why didn't the serial number show up in the South Bend Data list? It has me stumpt. There must be a glitch in the data base. Ernie
Picture of Brian C.
posted May 09, 2008 14:29
Ernie,
Try it again. It shows up in mine.
Brian C.
posted May 10, 2008 10:48
Brian: I tried it again. smae results, Not in the South Bend range of production numbers. ernie
posted May 10, 2008 12:46
Ernie,
Your watch is indeed genuine, however I too found the same glitch in our database.
Apparently a whole series of numbers in that one particular run are not showing as they should, so I left a message for Frank who I am sure will run this issue to ground. Typing in a Grade 211 of mine which is 1224087 all the runs of Grade 211 came up, including yours with this information...
1108001-1113000 shows up as being Grade 211 and 16-size, Model 2, 17-Jewels, from 1925 production, your movement is from the 36th of the 38 Grade 211 runs.
Grade 211 from the final 16-size South-Bend run...
posted May 10, 2008 16:05
I experienced the same problem with a couple of 0s watches, serial #'s 665675 and 676926. Neither of these are in the database list of production numbers.
posted May 10, 2008 21:27
Thanks for the heads-up Ernie, I'm sure Frank will be in there banging on the pipes and get it all straightened out.
South-Bend
Picture of Frank Kusumoto
posted May 13, 2008 03:06
Thanks for that error report. The database has been updated. There was a typo in that listing that was keeping it from showing up correctly.
The errors with the 0s watches are expected. I will update the database as reports come in. The original listing that I had worked out for the 0s watches had some missing information. As the reports come in the database will get better. I'm confident that the listings for the other watches (6s, 12s, 16s, 18s) are accurate but there may be some more typos in the 720 lines of data.
