October 03, 2008, 02:13
Frank KusumotoTwo Charts showing Production by Grade and by Year
Ernie Loga was kind enough to put these charts together based on the Grade of the the movement and the yearly production. They are both linked at
South-Bend Catalogs and Literature Hosted by IHC185 for convenience.
Here are direct links to the PDF files:
Chart of South-Bend Grades, Year By YearSouth-Bend Grades Produced In Each Year.
The information was taken from our lookup database. The two charts are an interesting way of looking at the history of the company and the evolution of the movement grades and production.
January 04, 2009, 04:11
John J. Flahive IIIErnie/Frank,
Thanks very much for posting this data. It really helps when trying to learn which grades are relatively scarce or common.
One correction, on the Production by Grade table, the Grade 407 is listed as 3100 produced, but I think this is supposed to be 30000. The totals will need to be readjusted also.
Best,
John III
January 04, 2009, 09:16
Ernie LogaJohn:
You are absolutely right. The total production of grade 407 should be 31,000.
Thank you for bringing this to our attention.
A corrected chart has been emailed to Frank for posting to his list.
Ernie
May 31, 2009, 13:40
Frank KusumotoThe links above have all been updated and are now working.
November 12, 2009, 18:49
Ernie LogaHere is a new link to the South Bend By grade chart. It was upgraded this fall and now includes the number of Jewels in each grade.
Production By Grade chartFebruary 28, 2011, 23:28
John J. Flahive IIIMoving this to the top so it is easier to find.
November 07, 2019, 08:38
Larry HelmsYour grades produced in each year seems to be incorrect as I have a 291 that was produced in 1907 #482200
