Detent Stem Removal "Click" to Login or Register
IHC Member 48
Picture of Keith Klimkowicz
posted February 27, 2011 11:01
Hi All
Does anyone have any tricks to remove a detent stem. I have loosened the screw that holds the detent stem in place and the stem will not pull out. I am posting a picture of the movement it is an early Hamilton 16 size 17jewel hunter movement. Thanks for any help.
Keith
Posts: 856 | Location: North Ridgeville, Ohio USA | Registered: November 19, 2002
Site Moderator
Picture of Tom Brown
posted February 27, 2011 12:31
I don't know if this is could be your problem, but I have seen these movements put in cases that you don't use the detent stem removal. The case is a normal case with a sleeve & the movement comes out like a non-detent.
IHC Member 48
posted February 27, 2011 13:23
Thanks Tom
I have tried to remove the movement from the case as a normal watch. No did not work.
Keith
Site Moderator
posted February 27, 2011 14:30
Sorry Keith, was just my best guess.
IHC Member 48
posted February 28, 2011 14:27
Got it removed... The trick is to remove the cap screw over the screw that hold the stem. Yes what you see flush with the plate is a cap screw. Just remove it and under it is the screw to loosen the stem. Simple!!!
Keith
