Waltham 1860 Disassembly "Click" to Login or Register
IHC Member 1650
posted February 02, 2016 23:34
I'm disassembling a Waltham 1860 KW 16s movement. How do you remove the canon pinion and center staff? It appears that the nub sticking out of the canon pinion is part of the pinion, and not a pin to be driven out. Any help is appreciated. I've attached some photos.
Thanks
Doug
IHC Member 1650
posted February 02, 2016 23:35
Pic 2
IHC Member 1650
Pic 3
posted February 03, 2016 06:09
Doug,
I usually put a little oil around the top of the canon pinion just to loosen things up. Take a bench block and center the square of the pin over an appropriate hole and tap very carefully directly on the end of the pin (extending at the CP ) and that should drive the pin right through the CP through the center wheel and out.
Rob
www.pocketwatchrepairs.net
Posts: 580 | Location: Kingsport, Tennessee in the USA | Registered: November 26, 2002
IHC Member 1650
posted February 05, 2016 00:15
Rob
I did as you suggested. It worked fine.
Thanks for the help.
Doug
posted February 05, 2016 05:39
Hey Doug,
Good news thanks for the follow up.
Rob
