Stuck front cover - successful removal! "Click" to Login or Register
Hello all,
I have a B&B 16S front cover that I cannot unscrew. I have applied penetrating oil and after
a day tried again, but no luck. Not sure what to do next without harming the bezel or crystal.
Any suggestions anyone ??
Don
Posts: 169 | Location: Adrian, Michigan in the USA | Registered: June 09, 2011
Picture of Brian C.
Try using a rubber jar lid remover. They also have a rubber cup shape thing, that's made for removing bezels and case backs.
Hi Brian,
I tried the rubber cup, (no luck). I'll look for a jar lid remover.
Thanks for the response.
Don
IHC Member 1541
Picture of Lorne Wasylishen
Donald, when all else fails you could try this.
Stuck Bezel Removal
I have since discovered that drilling holes is not required, if you can get it to adhere to a small piece of plywood for some grip it should work.
You may want to clean the penetrating oil off as much as possible first.
Hi Lorne,
What type of glue is best to use, and what do you use to remove the glue from the crystal afterward.
Thanks for responding,
Don
Picture of Thomas M. Cusack
Try hot glue gun works great,peal off glue when done
Posts: 175 | Location: New Hampshire in the USA | Registered: March 04, 2015
Tom,
I'll have to get one of those and try that.
Thanks for the response and tip.
Don
IHC Member 1541
Electric hot glue gun and remove with lacquer thinner(acetone).
The thinner certainly doesn't just dissolve the glue instantly, takes a few min. to migrate but a little wiggling will encourage it and as Thomas said the glue will peel off.
If the crystal gets stuck just watch closely and you can see the thinner work it's way thru.
Lorne,
Thanks , I'll try that.
Don
Brian, Lorne, Tom,
Thanks for the help in getting the cover off. The glue gun trick worked great. I was able to peel the glue off the crystal after popping off the piece of wood.
Thank you every body,
Don
