Wrist watch stem removalGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
What is the procedure for removing a 2 piece winding stem from a Bulova automatic? I have googled this and if I understand correctly, the stem is a kind of male knuckle that snaps together into a female socket. Apply some leverage to the crown and the stem parts will separate. Is this correct? Help me out here please. | |||
Gary I am no expert but that is what I have always heard and they even sell a puller that will pull them. I always was nervous of doing this (afraid it might break) so I always have turned the knuckle upwards and with stem out in setting position I just slip the movement out of knuckle then the female part of stem connected to the crown will slip right out. | |||
Thanks Robert, as it turns out, the watch I wanted to remove the stem from has a screw that needs to be loosened slightly. I did try removing the stem from a parts watch as you described, worked with no problem. Happy Holidays, Gary | ||||
