February 09, 2014, 20:26
Roger Stephens992B set lever
992B set lever
is very hard to get to.I have to use a small sharp
object to pull it out to setting position.It is a sig.2 ina model 2 case and 080 dial.any suggestions?
February 09, 2014, 22:07
Jon HartHi Roger
Please see the below pics
There is a screw that holds the lever in place (usually has a blue head)
So, you would have to remove the movement from the case, remove hands, dial, etc..
Jon HartDial side - red arrow points to the tip of the screw holding the lever set in place
