IHC Member 1357 |
992B set lever is very hard to get to.I have to use a small sharp object to pull it out to setting position.It is a sig.2 ina model 2 case and 080 dial.any suggestions? | ||
Hi Roger Please see the below pics There is a screw that holds the lever in place (usually has a blue head) So, you would have to remove the movement from the case, remove hands, dial, etc.. | ||||
Dial side - red arrow points to the tip of the screw holding the lever set in place | ||||
