Removing key set square? Elgin Model 4 Size 10 "Click" to Login or Register
I have a size 10 Elgin model 4 KWKS watch. The center wheel pinion has the setting square fixed on one end. What is visible is a steel square with a small flange against the plate. How does one remove this setting square? I have several of the best repair books but I can't find this question answered in any of them. Thanks in advance!
John
Posts: 4 | Location: Dayton, Ohio in the USA | Registered: June 09, 2013
Picture of Brian C.
John, that center wheel staff is pressed on. What I do after removing the cannon pinion is give the staff a light tap with a brass hammer, and the shaft should pull right out.
Thanks very much. That worked perfectly!
