Correct way to let down m spring on a full plate.
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/907007866
February 03, 2004, 18:13
Kevin Pestor
What is the correct way to let down a mainspring on a full plate elgin movement.
I know how to do the three quarter but this is a different set up.
Thanks again.
Kevin "Veritas" West
IHC Member 261
Chapter 111,Ottawa
NAWCC Member 158976,
Nepean, Canada
February 03, 2004, 18:52
Aaron Bereiter
Kevin,
There should be a small hole on the side of the movement you can put a probe into to engage the click. This should release the click and allow you to let down the mainspring with a bench key.
it is a lot easier to spot with the dial removed.
Aaron
February 03, 2004, 20:53
Kevin Pestor
Thanks Aaron, i found the hole, i never noticed this hole before.
It worked well i used a bench key like you suggested. Cool Smile
IHC Member 261
Chapter 111,Ottawa
Nepean, Canada
