Cannon Pinion FrozenGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Would anyone have a "trick of the trade" for a frozen, ie rusted I would think, cannon pinion.. A mid 1870's lever fusee.. I have tried gently tapping the center post down with the correct sized punch, gently twisting with the proper key, no movement.. Thanks for any workable tricks here.. | |||
Try some WD-40 on it. It will probably take a few days of soaking,but should work. Frank | ||||
In our progression of things that we do when parts are frozen.... heat is always near the top. If you don't have a drier-box, use a hair-drier, set to high. It shouldn't hurt anything in the watch (we use higher heat than that for drying after cleaning). You might get that cannon to expand a bit and break free. Hope this helps. | ||||
| IHC Life Member South-Bend |
Another neat trick I learned from an old watch maker is Jojoba oil. Soak for about 24 hours. PB Blaster is a good penetrating oil and so is Kroil. I'd try one of the different oils, let it soak, if that doesn't work try Pete's heat suggestion. Frank "407" Kusumoto | |||
Frank, Peter, and Frank, That sounds like an Attorney firm... Back together already, runs and most importantly SETS, like new.. John Pavlik | ||||
