IHC Member 229 |
Hi Folks....need some advice from you Hamilton experts....I getting ready to disassemble a 12s grade 912 17j Secometer movement. How do I pull the small fragile looking seconds dial without bending or damaging it? | ||
CAREFULLY TONY, VERY CAREFULLY... I don't hold myself out to be an expert on watch repair, but here's what I can tell you. The Secometer dial came on one particular grade, your 912 as factory available but was a jeweler-installed option as it were for any other Hamilton 12-size. Therefore you'll find the seconds disc goes on in the same manner as a conventional second hand. It just pushes on. I would think that once the dial feet are loose for sure, then something thin, strong and flat such as a credit card might be of help to you. But let's see what others come up with! Lindell ![]() | |||
IHC Member 229 |
Well, I cut 2 short pieces of mainspring...shaped them ...and used them as 2 tiny pry bars...held my breath...and...that little Secometer Dial popped right off. Now, I have to find a Roller Jewel and...I know I'm reaching here...But...a nice used or NOS Dial...Any body??? | |||
The roller jewel should not be a problem as parts are pretty readily available for Hamiltons. Check with Brian Cavanaugh at pwpartsetc@pwatch.com for that one. On your dial question, I'm a little confused. What sorts of problems are you having with the Secometer Dial that came on it? Finding a better or NOS dial of the Secometer design could be a tall order. On the other hand, a standard dial should be fairly easy to locate. Lindell ![]() | |||
Thanks Lindell, I should be able to help Tony with the jewel. Tony, if your dial is just faded or scratched, you could send it out to be redone. Brian C. | |||
IHC Member 229 |
OK...Sorry for the confusion... The SECOMETER DIAL is in good shape on this 912...I successfully removed it and hopefully it will go back on without a problem...the larger PW Dial is metal and in bad shape...it has that little window in it which exposes a small section of the little secometer dial indication (a seconds hand fuction.) Since the roller jewel is readily available...I'll see if I can locate one...Or two locally..those little guys have a mind of their own....when they are in the jaws of a tweezer...Boy all this help is great thanks guys. | |||
