March 08, 2015, 18:56
Patrick WallinElgin 12s, 17j, G, 383 (h3n2p)
The safety pinion let loose of the gear.
There is the pinion shaft, the wheel, the gear and a tiny washer.
How tight should I put the gear on the wheel and where does the washer go? Between the bottom of the gear and the jewel or between the gear and the wheel?
March 08, 2015, 21:19
Gary E. CochranPatrick
The washer goes between the wheel and the gear..Just snug the gear up on the center wheel doesnt have to be tight the mainspring barrel will hold it on as tight as it needs to be...
March 09, 2015, 00:41
David AbbeThat's the "Fogg's Patented Safety Pinion".
March 09, 2015, 18:43
Paul D. TrombleyIt took me a second to realize this is a frog joke... You made me laugh
March 10, 2015, 02:53
William D. WhiteThe safety pinion is one of the most elegant inventions ever. A mainspring letting go at full wind can cause horrendous damage to any watch no so equipped. ...and zero damage to one that is!
William
