I am thinking that the front doesn't have a bezel that comes off so use a crystal lift and remove crystal and movement should come out from the front...
Posts: 2027 | Location: Chesapeake City, Maryland in the USA | Registered: September 27, 2011
I'm trying hard to remember but I think it comes out the back after the stem is removed. I have one just like it. I don't remember any special problem in that area, but it's been a while.
Both of these cases appear to be the same.
Dave Turner
Posts: 1979 | Location: Wilson, North Carolina in the USA | Registered: November 15, 2011
Karim, Dave is probably right that the movement comes out the back..It looks like there is a medal movement ring on the inside of the case holding the movement..These sometimes fit a little snug on the outside of the inside of the case (if that makes since) and over time get a little hard to remove..Movements that come out the front are usually in waterproof cases and this is not a waterproof case. If you try to remove that ring and the movement should come out easily..
