Bulova Accutron 214 resistence valueGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Hi all. I tested the circuit of my 214 accutron and it´s bad. I want try to change the resistence. Do you know the correct value of it? I think is a 0.25 watts 2.2 Megaohms with 0 tolerance. I´m correct? Thanks Manuel | |||
The colored bands if 2.2M will be red red green uncomon for resistor to fail, to test you need to test with one leg free from circuit. | |||
Thanks Abell. so what is the more common problem in accutron circuit in a watch that not hum? If I put a incorrect battery wihtout the spacer ring I can burn the resistor or what part. I understand that If don´t see the watch it´s impossible a true diagnostic but please give me some light. Thanks Manuel | ||||
