jewel mountingGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a mounted pivot jewel that is a tad too big to go into the hole on the balance cock.The jewel is part of a selection I ordered from Larose. They where marked to fit the Elgin movements.My question is,how do I go about removing the excess brass to make the fit. Do I use a lathe, if so, what type of chuck would work, as the excess is on the whole diameter, not on the shoulder of the mounting. Any suggestions appreciated Frank | |||
Frank, You really need a set of jewel chucks here. These chucks have an adjustable (for depth) center so that the jewel setting will fit flat in the chuck with any amount exposed that you desire. If the entire outside diameter is constant, mount the setting about halfway in and reduce the diameter as needed. Then reverse the setting in the chuck so that just a little bit of the reduced diameter is exposed. Cut the setting down until it is flush with the first half. Ed Ueberall IHC Member 34 The Escapement | |||
Hi Ed Thanks for the reply. I was afraid that was the reply that was going to come up. I have been trying to snag a set, but sofar, no luck. Well I guess I'll have to get real serious about acquiring a set. Thanks again Ed. Frank | ||||
| IHC Life Member Watchmaker |
Frank, Dashto.com usally has them. | |||
Scott Thanks for the tip. I will check his site out. Frank | ||||
This is a little late, but I just got around to doing the job. Ed, those jeweling chucks worked out great. I found the one I needed, out of the set I bought. I was able to place the shoulder,of the mounting in the chuck, and take down the O.D. to fit the opening. Everything worked out fine ,and the Watch has been placed in the "Repaired Box". Thanks for your help. Scott, I picked up the chucks at Dashto's. Frank | ||||
Frank, I love it when a plan comes together! (Apologies to George Peppard) Ed Ueberall IHC Member 34 The Escapement | |||
