January 28, 2015, 13:19
Lorne WasylishenStuck two piece bezel question
Nice work Dave.
What is the generally accepted procedure for re-bluing the case?
January 28, 2015, 14:05
Dave TurnerGood question Lorne,
I didn't research that procedure too much. But I did learn that you can buy a kit for re-bluing yourself.
This does not however replicate the original factory procedure. And I don't know what that entails.
January 28, 2015, 14:29
David AbbeTo re-blue the "gun-metal" appearance of this case which is actually a black color, I would enquire of a gunsmith and see if they could help.
January 28, 2015, 15:26
Dave TurnerDave,
I had the same thought. I have a friend who's a "gun nut". He probably knows. I haven't asked him yet.
January 28, 2015, 18:53
Buster BeckFollow instructions, it's very simple.
http://www.ebay.com/itm/Formua...&hash=item3a9f2507b9 regards,
January 28, 2015, 19:12
Peter Kaszubski44/40 will works like a charm on that case and you can reapply to make it darker
January 28, 2015, 20:36
Dave TurnerThanks Peter,
Wish I hadn't already mailed it back to my brother in law.
Not having any experience with this, could it be applied without removing the crystal and brass parts without damaging them?
January 28, 2015, 20:48
Peter Kaszubskiwell I will suggest to start in some part that can be rebuff just to see how is working, as with all metals no same result can be achieve, once happy I will dip the case for few seconds at a time wash and repeat if necessary,fallow the instruction on battle.
and yes I will remove the crystal and brass unless
you want to rub the liquid on the case.
