Stiff winder "Click" to Login or Register
Stiff winding problem. 16s Elgin was so greasy it wouldnt run. After a cleaning and oil it runs like a champion but winds hard. I removed the ratchet wheel with the movement still in the case and the crown turns like butter. This tells me that the crown wheel and the case stem are free and good. With the ratchet wheel off I can move the winding arbor a littla and it appears to turn freely in the plates. I installed an NOS mainspring and oiled with Moebius 8200. What could it be? Could the cap on the mainspring barrel be holding it tight? Sounds kind of unlikely to me. At first I thought maybe the mainspring was to stiff but it does not seem to run with too much power. No overbanking or knocking. Any ideas?
Aaron Bereiter
NAWCC# 156432
Chapter 185 Charter #55
Chapter 185 Finance VP
God bless America
BTW, What would happen if a mainspring was wound into the barrel backward? Could this even be done and if so would the watch run?
Problem solved. Smile
Ten minutes on the phone with Ed and were up and winding like silk. The old fear of overlube got me this time. The crown wheel between the wheel and the center arbor was dry and binding. She winds smooth as silk.
I was going to delete this but maybe it could help another amatuer so I'll leave it.
Thanks Ed!
Aaron Bereiter
NAWCC# 156432
God bless America
RR Watch Expert
Picture of Ed Ueberall
Aaron,
Yes, a mainspring can be wound into a barrel backwards. I don't want to go into any detail, but I know! Frown Roll Eyes
However, the watch won't run, as the arbor hook will not be able to engage the hole in the end of the mainspring. When the watch is wound, it will feel like a broken mainspring. Usually if you also put the arbor in upside down (so now the arbor hook will engage the mainspring hole), the assembled barrel cannot be put back into the movement, as the barrel teeth will not engage the center wheel pinion.
Ed Ueberall
NAWCC #49688
IHC #34
http://members.aol.com/stdwatch/
Maybe that explains the stiff winding on a Waltham I just fitted a new mainspring into. It winds very easily while tightening the ratchet wheel screw, but is exceedingly stiff when winding through the stem.
With the barrel out, the crown and stem spin freely ... BUT ...
I will try looking at lube in the crown wheel and such, and report back tomorrow on my success, if any.
This sounds like one I have , thank you
