This watch has an extra wheel?? "Click" to Login or Register
Picture of Jim Robson
posted June 11, 2007 22:36
Hello, I just got this 1942 Bulova with a 10AX movement. I am puzzled by the "extra" wheel. What does it do? The normal power train is visible and it doesn't appear to be part of the power train.
Whatever could it be?
Thanks, Jim
Movement
Posts: 116 | Location: Tulsa, Oklahoma USA | Registered: February 07, 2007
posted June 11, 2007 22:37
Dial side
Dial side
RR Watch Expert
Picture of Ed Ueberall
posted June 11, 2007 23:51
Jim,
The sweep center second hand is the clue for the "extra" wheel. Normally, the second hand is a long pivot extension on the 4th wheel, which rotates once a minute. On your watch, the 3rd wheel has a gear on top of the plates with the same number of teech as the normal one, located down between the plates. This "extra" wheel drives a pinion gear that extends down through the hollow center wheel and cannon pinion. This pinion will now also rotate once a minute (just like the 4th wheel) and the sweep second hand is attached to the long shaft that is part of the center pinion.
Ed Ueberall
IHC Member 34
The Escapement
posted June 12, 2007 06:49
Thanks Ed, With your great explaination it makes sense.
Regards, Jim
posted June 13, 2007 19:24
Jim,
Ed is of course correct, but I wanted to add that this arrangement is often referred to as an "indirect center (or sweep) seconds" movement.
Cary
Posts: 267 | Location: Huntsville, Alabama USA | Registered: December 12, 2005
posted June 13, 2007 20:49
Thanks Cary, I'm sure glad I have such a rich resource as the people on these boards. I have so much to learn Smile
Regards, Jim
P.S. Lyndell would be quick to remind me that there is no such thing as a dumb question, except the one that you don't ask.
