Cleaning solutions
March 17, 2015, 21:36
Chris AbellCleaning solutions
I had few people ask what is my preferred watch cleaning solutions. I use to use L&R but had problems with residue so I changed several years ago to Zenith and had good results since.
Formula 67
During the cleaning cycle with Formula 67, hardened grease and oil are dissolved and particles that have adhered onto metal parts are dislodged by micro-molecular action. All this cleaning power is being accomplished with a safe and environmentally friendly cleaner. After the cleaning cycle movements are ready for the Rinsing Cycle.
Rinsing Solution - Drizebrite, Product 101
The rule is: Rinsing Solutions should have the same solvents as the cleaner in order for it to be most effective. Zenith's Drizebrite rinse has the same solvents as Formula 67 cleaner. Be reassured that the rinsing action is thorough and complete because of the similarity of solvents in both products. What makes Drizebrite rinse unique is its Odorless rating and the fact that it leaves parts spotless without any oily film. When ordering Formula 67 always include Drizebrite as the rinsing solution.
March 18, 2015, 00:16
David AbbeThanks for the advice Chris. Cas-Ker has these.
March 18, 2015, 02:33
Peter Kaszubskiso does Esslinger and few others.
March 18, 2015, 14:45
Patrick WallinGood to know I have been doing something right.
March 18, 2015, 15:48
Bruce BonbrightCan these products be used in an ultrasonic cleaner with good results?
March 18, 2015, 17:44
Larry LamphierBruce, yes it can be used with an ultrasonic cleaner.
Zenith Formula 67 is Ammoniated.
I thought that I had heard SOMEWHERE that ammonia can damage the finish on some of the older plates. Is that NOT true?
I use the L&R Heavy-Duty #677 "Clock" Non-Ammoniated Waterless cleaning solution, with the #3 L&R Rinsing Solution. On the railroad watches that I do the plates come out looking like new.
I had called the person selling them, and he told me to use the HD clock cleaner rather than the watch cleaner. I believe he was also the one who told me to stay away from the ammoniated solution. ??
March 18, 2015, 18:28
Chris AbellHi Bruce,
The cleaning fluids have been developed for cleaning wrist and pocket watches of all ages in a ultrasonic and other cleaning machines, they also are must safer with less odors than other products and will not cause damage. Of course like any other product they need to be used correctly and changed when contaminated. You have to remember people will use all kind of inappropriate oils, cleaning solutions prior to arriving for service. Pre cleaning and inspection is essential. I tried the "777" cleaner and did not see any improvement so returned to what I know works.
March 18, 2015, 19:32
David AbbeThe cleaners discussed here are probably all effective, I must thank Chris for the advice and hope it is taken as such.
March 18, 2015, 19:51
Larry LamphierFor SURE David.
I didn't mean anything but an HONEST to goodness question here. If it was taken any other way I apologize to everyone, and especially my friend Chris.
March 18, 2015, 19:55
Paul D. TrombleyChris, thank you for sharing your experience with us. It cuts out a lot of trial and error for me.
This is one of several processes in my studio I was still trying to get right.
March 18, 2015, 20:12
Bruce BonbrightThank you all so much for the info. Chris, I'm ordering the Formula 67 and Drizebrite per your advice. This is such a great forum!
March 18, 2015, 20:19
Samie L. SmithI use l&r #111 cleaner and L&r #3 rinse and have nothing but good results using them..
March 18, 2015, 20:43
Chris AbellI have two tempo 400 fully automatic machines, rotation and ultrasonic cleaning action, they use approximately 1 gal of fluid to fill all 4 jars with a little top up left, I like 2 clean 2 rinse I know some watchmakers prefer 1 clean 3 rinse. doing it professionally I keep the fluids fresh and get typically 10-20 cleans between fluid change. if I used a watch master I would change them much more frequently. I save the dirty solution and use for cleaning gun parts,bicyle chains, small engine etc and often I pass it onto a local guy who does clocks and he uses it until it turns to black soup! buying in bulk direct I get chance to speak to the chemist at zenith he is always keen to hear how it performing in the field and keeps me up to date on latest products. I am told it will keep cleaning even when severely discolored and explained how it all worked quickly lost me with his explanation, I also used the 555 hairspring cleaner which works well less hazardous than one dip but slower to dry.
March 18, 2015, 21:09
Rafal WolerI would try Zenith but for some reason is not available in Europe. So, I did my try and error process, and finally, Ive took advice from watchmaker Im friendly with. He advised Elma 9:1 as a cleaning and for rinsing special kind of naphta (very clean one, no additions) - 2 times, and so far its the best combination for me, no issues with residue. And its not expensive
March 18, 2015, 21:32
Bruce BonbrightI just checked with Esslinger and Otto Frei and neither ship to Hawaii. So back to the drawing board here to find something available over here to use.
March 18, 2015, 21:40
Chris Abellhey Bruce call them direct see if they will ship ground,
For pricing and availability please contact us at: 1.888.777.6887
zenithsolutionsinc@gmail.com
March 19, 2015, 13:18
Bruce BonbrightWill do, thanks for the suggestion. -Bruce
