I have a nice gold filled case with the bezel threads buggerd up. It has not been droped or dented. The frame and bezel/ back are round and flat. If you toy with it you can get them on and they screw off fine. Any recomended way to clean up the threads? If it was a bolt and thread it would be no problem. ![]() Maybe a formula for a light abrasive paste to act like a thread chaser? Any suggestions are grately appreciated. Aaron Bereiter NAWCC# 156432 Chapter 185 Charter 23 Chapter 185 Finance VP God Bless America | |||
IHC Life Member |
Aaron, If you haven't already, soak the case parts overnight in your watch cleaner. Sharpen a tootpick or piece of peg wood and completely clean the threads. Rinse and dry the parts and lube the threads and stem sleeve fingers a touch. I wonder what ever happened to all of the old case tap and dies that were used to build these cases. I'm sure some of the case repair companies that have been posted elsewhere on this board could chase the threads for a nominal fee. John D. Duvall NAWCC Member 144772 NAWCC IHC Happy Camper 192 Chapter 185 Watch Repair Moderator | |||
Aaron, I use a small dab of auto valve grinding compound on the case threads and keep working the bezel or back cover back and forth until they screw on easy. Make sure the watch is not in the case when you do this and that you clean the case well before installing the movement. Brian C. pwpartsetc@webtv.net | |||
IHC Life Member |
Brian, I will be making a trip to see Manny, Moe and Jack tomorrow. I've got an 8-day car clock bezel that is now squeaky clean but still a little stubborn to screw on and off. Thanks for the great tip! John D. Duvall NAWCC Member 144772 NAWCC IHC Happy Camper 192 Chapter 185 Watch Repair Moderator | |||
To add to Brian's suggestion, keep this stuff off the crystal and balance of the case. I scarred a crystal with this stuff sooooo fast you wouldn't believe it. Charlie | ||||
