This feels strait out of Outer Limits. I have this Hampden 3-Ball (17j railroad watch from 1899) which I planned to sell, so I carry it for a day and it stops. Only problem is I have already listed it on ebay. I never really got a chance to even time it. So I tear it down and find nothing wrong (nothing jumped out and said: help me), so I clean and oil this beauty. While timing it on the bench I see good balance action but she is minus almost 15 minutes after only 12 hours. I set the second hand with another watch sitting next to it (a real accurate Burlington) and guess what the second hand is keeping perfect time (less than 2 seconds in 12 hours). How can the second hand be dead on and the watch be off almost 30 minutes in a day? After discussion I will give the answer which drove me crazy, because the watch is now sold and it is still in the outer limits after all the usual answers did not work. mike paynter PS: I did not solve the riddle, Ed Thouvenin took me down the yellow brick road and the 3-Ball found its way home with accurate time.
Posts: 87 | Location: Home of Hampden Watches, Canton Ohio USA | Registered: January 18, 2004
Sounds like everything is fine at least to the 4th wheel and possibly the 3rd wheel. Did you find an incorrect center wheel with too many teeth or something else having to do with the train gear ratios?
Ok: here's the full story. Ed took apart the watch and told me to count the teeth on the 4th wheel. 80 just like it was supposed to be. He then said count the leaves, and I said what. I am bad on terminolgy and did not know that the little teeth on the wheel which connect with the 3rd wheel are called leaves. And here is the problem. Some former watch guy replaced the 4th wheel and did not check the leaves on the two wheels. The older slow train had 8 leaves and the newer fast train had 10 leaves. Well how come it did not bind up. Well it did on occasion, and thats why I cleaned the watch. But the 8 leaf wheel had a thinner pinion for the second hand and allowed it to slightly wobble in the jewel and not bind up all the time. All the other wheels were correct. The watch now sits on my bench with the second hand still correct and now the hour and minute hands as well.
