Hunter Case Winder "Click" to Login or Register
IHC Member 234
Picture of Jim Cope
...being relatively new to watches, I've come across a question that I can't find the answer to in any of my references...I have an 18s Waltham hunter cased watch w/o a stem/crown...now I have a stem/crown that fits into the sleeve and operates the winding/setting mechanism (lever) but since there are no threads to take a holding sleeve, I'm at a loss as to how to secure the stem in the sleeve...btw: there is a threaded hole in the side of the sleeve which I assume may somehow secure/release the stem...thanks for any help...
Picture of Jerry Treiman
My guess is that this case is an older style designed only for a lever-set movement. This case would not need a sleeve. Jim, when you say "sleeve", are you referring to the pendant tube? The threaded hole in the side of the pendant is for a screw to retain the stem in the case. The stem would be very simple, with a groove around it to catch the set screw. The groove should be wide enough to accomodate the inward motion of the stem when you open the cover. [This explanation is clear in my mind, but did I succeed for your purposes?]
Picture of Kenny Drafts
Here`s a sketch I did a while back for a similar discussion.
Hope it enhances Jerry`s explanation.
Smile
EDIT: As Jerry stated the groove should be wide enough to allow some "play" for the stem to be pressed to open the HC. The pic doesn`t show this as it was intended for OF.
Kenny
LS Stem setup
IHC Member 234
Picture of Jim Cope
...thanks Jerry...yes, I meant that the "pendant tube" was not threaded to receive a sleeve...now I
must find a set screw and a stem w/a receiving groove that will allow the stem to be secure and at the same time still allow the hunter case cover to be released?...thanks much!...
Jim
IHC#234
IHC Member 234
Picture of Jim Cope
...thanks too Kenny!...'tis clear what type of stem I have to find that will accommodate the set screw, wind/set the mechanism and still be broad enuf to activate the case cover spring...much appreciate both your efforts...
Jim
IHC#234
