  Detent stem:  Waltham Royal Model 1888Go  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
| IHC Member 1357 |
 Detent stem on a Waltham Royal Model 1888. The stem does not pull up to set time nor by loosing the detent screw the stem will not pull out of movement. How far can I loosen the screw. Sure would like to get movement out of case. Any advice appreciated. Roger  | ||
| IHC Life Member  |
 Roger, The stem release screw needs to turn counter clockwise until it stops. Even then, sometimes time takes some wiggling to get the locking pawl to let go, old grease and dirt stick it in place. Sometimes releasing the movement screw helps, too. That may also be why it will not set. Cleaning and new oil usually fix both problems. Hope this helps. Steve  | |||
| IHC Life Member Certified Watchmaker  |
 Easy way is just to take the barrel bridge off while inside the case and see what's going on.  | |||
| IHC Life Member  |
 Thanks Chris, You pros know all the easy ways to do things! Steve  | |||
| IHC Member 1357 |
 Thank you guys. Got it done Roger  | |||
