Relieving tension on mainspring "Click" to Login or Register
Picture of David A. Vasarab
posted July 18, 2011 20:31
I have a Hampden size 6 and the mainspring is below the plates. I cannot winf it so I'm thinking that I should relieve the mainspring. How can I access it?
Dave
Posts: 76 | Location: Parma, Northern Ohio USA | Registered: January 02, 2006
Certified Watchmaker
Picture of Chris Abell
posted July 18, 2011 20:45
Dave,
If you look at the edge of the lower plate you may see a small hole to insert a pin to release the spring, of course unwind slowly.
posted July 18, 2011 22:03
Thanks Chris,
You are correct as always. However, this is so intricately small, I will leave it up to your expertise.
When I have a couple of more watches that need your attention, I will contact you.
Dave
posted July 19, 2011 06:08
Thanks Dave,
Look forward to seeing them,
Chris
