March 10, 2007, 17:31
Dan MitchellSnap-on case-back problem
Is there any way of tightening a loose snap-on, gold-filled wristwatch case back. Mine goes on and stays on OK, but is loose and can be rotated.
Dan.
March 11, 2007, 00:19
Cort MooreHi Dan,
You could run a mill-grain tool around the underside lip of the bezel or case back. The mill-grain tool is essentially a hand held micro knurler, used in jewelry work. This works well when just a bit more grip is wanted. The marks left are very subtle and the process is simple and less perilous than burnishing or attempting to reform the case.
-Cort
March 27, 2007, 17:26
Scott CerulloCort,
Could you post a pic of the mill grain tool?
Thanks
