Case Repair "Click" to Login or Register
IHC Member 229
Hi All....I am about to attempt some hinge repair on a few Gold Filled PW Cases....what kind of SOLDER should I be using...and....where is it available?...Thanks.
Posts: 148 | Location: Somerville, New Jersey USA | Registered: November 28, 2002
Watch Repair Expert
You should be using gold solder and a jeweler's torch, and if you're not, you're about to mess up.
Common lead and/or tin solder isn't nearly strong enough for case hinge repairs, and it will adhere to the metal, thereby making any future repairs much more difficult, if not impossible.
If you've never attempted to solder hinge segments on a watch case before, I'd strongly advise you to practice first on some that aren't too good. First, apply a small amount of solder to the tube section itself, and make sure it adheres well, then apply some flux in the groove in the case, place the hinge tube in position, and heat the case directly below the tube until the solder flows and sticks to the case.
As long as you held everything in proper position, you didn't allow the tube itself to fill with solder, you didn't apply so much solder that it bubbled up at the ends of the tube, and you didn't apply so much heat that you melted or distorted the case, you shouldn't have anything to worry about!
Steve Maddox
President, Chapter #62
North Little Rock, Arkansas
IHC Charter Member 49
Yikes!
You make a very difficult job sound...very difficult... Steve!
That's one repair I'd definitely steer clear of!
IHC Member 229
Sounds like a whole new learning curve...where do I get this "gold solder"?
Here you go. I found reference to SO-490 as a low temperature gold solder should get you started soldering your gold.
Aaron
Watch Repair Expert
Case repairs are a specialty of their own, and I try to avoid them whenever possible. I've done a few of my own (enough to know how difficult it is, especially for someone without a background in jewelry work), but I wouldn't feel good about working on anyone else's.
Fortunately, I do have a recommendation, which is Wuischpard & Son, in Florida.
http://www.watchcaserepair.com/
The father was the "W" from the "S&W Watch Case Co.," which produced most of the asymmetrical Hamilton Electric cases, etc. I've never sent anything there myself, but people I respect tell me they're the best in the business. They can even fabricate cases from scratch, but I'll bet that would cost an arm and BOTH legs!
As always, I hope this helps!
Steve Maddox
President, NAWCC Chapter #62
IHC Member 229
OK...thanks for the input...I think I'll order some...SO-490 from S.Larose...and play a little
...if I'm successful...I'll get back to you folks...if I'm not.....I'll be....Hiding
