940 Cannon Pinion Tightening "Click" to Login or Register
posted April 18, 2003 17:44
What's the correct way of tightening the type of cannon pinion found on a Hamilton 940? Here's a picture of one for reference...
Mike Miller
NAWCC Member# 154831
NAWCC-IHC Charter Member# 27
Picture of Jerry Treiman
posted April 18, 2003 21:51
Mike, if I am not mistaken the pictured canon pinion is already broken. There should be a flange of steel on the open side of this piece that is missing. There is no way to tighten this one.
Picture of Brian C.
posted April 19, 2003 09:27
Mike,
This is certainly not a fix but it might get you by until you get another cannon pinion. Put the hand end of the pinion in a staking block so the hole in the pinion is facing up. Take a three corner punch and tap it in the hole lightly so you make a burr in it. This may tighten it enough for the time being.
Brian C.
posted April 19, 2003 10:00
Thanks Jerry and Brian,
I was wondering if it might be broken. Guess I had better start hunting around for a replacement. The three corner punch did the trick for now.
Mike Miller
