Center wheel interchangeability question (992 / 992B)Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
I have a 992 s/n 302358 that needs a center wheel. Would one from a 992B fit? Roger | |||
hello roger, No a center wheel in a 992b is different from the 992 model..they don't interchange Paul Davis | ||||
Roger - Paul is right they do not interchange. I have at least one spare center wheel and cannon pinion for a 992. Let me know if you need one... Some of them are with a brass finish and some plated gold. The early ones have the brass finish j | ||||
Thanks Paul and Jon for the info. Perhaps I don't need one this movement is from 1903 2nd. run of the 992's so it is a early one. All of the other 992's that I have (11 pcs.) have the gold wheel. So I thought all should have them. I do have one from 1906 that has the gold wheel. Thanks guys! Regards Roger | ||||
No problem roger, if you'd like to fix the 992, its suppose to have a brass center wheel and you can interchange the one from a 974 to make it easier to find one... Paul Davis | ||||
Thanks Paul.The watch runs a little slow.I have 3 992,s that need a COA and will be sending to you in a short while. Roger | ||||
That would be great roger thanks Paul Davis | ||||
