November 02, 2014, 18:50
Bruce ParsonsMontrex Stopwatch will not reset (flyback)
I have a Montrex stopwatch that will work but not reset. It has a movemenet stamped Ilona Lt. GR Swiss Made One Jewel Unadjusted. There is also a large "G" with BF inside of it and the number 410.
The watch starts and is wound with the stem and the reset mechanism is set with a seperate button at the 52 second mark.
It winds and runs ok but will not reset. There is no resistance when the reset button is pressed and nothing happens.
I realize that the stopwatch does not have any intrinsic value to speak of and would not mind trying to take it apart to fix it but I cannot find any information on this particular movement or how stopwatch mechanisms work.
My question is: Based on your experience with such stopwatches, do you suppose something could be done to make it work if I did take it apart? Or does it sound like something may be broken and beyond repair.
Thank you in advance for your help.
November 04, 2014, 20:40
Eugene BuffardThe only way to find out is to take it apart. Have you ever worked on a watch.
