January 03, 2023, 08:46
Larry HelmsElgin convertible clutch lever screw
Does anyone know what the size and length is for the Elgin clutch lever screw on an Elgin convertible grade 49? My screw goes into the whole without the clutch lever but does not tighten down with the lever in place. It looks like the first part of the screw hole is stripped. Is there a longer screw? Do I need to retap the whole?
January 03, 2023, 12:28
Douglas D. WeaverMy suggestions would be:
1. Close the hole slightly using a hole closing punch in your staking set. Since the plate is softer than the screw, it is often possible to recut threads into the plate.
2. Find a longer screw. You need to have an assortment of miscellaneous screws to search through. I bought an assortment on eBay with thousands of screws. Very handy.
Doug
January 25, 2023, 11:52
Larry Helmsupdate: purchased 0.8mm x 2mm screw from mcmaster carr and a tapp. Used a broach and made the spring hole larger for the screw. Tapped the whole and the screw is holding.
